engines that won't run with cover on
P51D
I've read a lot of posts about JohnyRude 9.5 hp engines and their exhaust leaks, causing engines to stall. Sounds like some years/models are more prone than others, and some are harder to fix than others. I'll be looking at a 1973 Evinrude 9.5 hp this weekend. The model number is 9322B, and the serial number is J 07865. <br /><br />Can someone explain which ones are vulnerable, and why? Which are hard to fix and why?<br /><br />THANKS
Basscat 1
Re: engines that won't run with cover on
I would be more worried with checking the compression than an exhaust leak.
JB
I think all of the low profile 9.5s are prone to exhaust leaks, P51D
