seadrive 2.0
groundhogday
Hello everyone, Well, this is my first post on this forum and it's an S.O.S . I am the proud owner of a good ole 89' omc 2.0 seadrive v4 140 horse pain in the neck. A good tried and true outboard , but man, I've had the worst of luck. She's low hours and in dire need of use but the bugs are killin' me. Last of all, I had a parts guy give me the wrong rectifier/regulator and, well, lets just say it was expensive and a fire extiguisher was involved. Bad, bad day. I need some parts. I'm looking for parts or entire motor for the above mentioned animal. Hope someone can assist. IF anyone has any questions, please ask. I've learned quite a bit from owning this monster.
Dhadley
Re: seadrive 2.0
Welcome!!<br /><br />I hope the parts guy stood behind his mistake for you. I can imagine the fire that caused. You can put a 35 amp reg/rec on a 10 amp system but you sure cant put a 10 amp reg/rec on your 35 amp system. Definately a boo-boo on his part unless you identified the motor as a 2 liter 140 outboard.
groundhogday
Re: seadrive 2.0
Can anyone tell me about converting other stators to work with the existing components? I figure as long as the wiring is coded the same it should work. I've found a few with similar wiring but not sure if this is gonna be anothere flambe' in waiting. New stator costs 200-325. Looking for someone wanting to repower their vessel and pick up some parts motors.
Dhadley
Re: seadrive 2.0
We're not quite sure what you wany to do. We assume the reg/rec is burned up and needs replacing. Any 35 amp reg/rec for a V4 Sea Drive looper or any V6 & V8 looper will work. Any looper 10 amp reg/rec will result in the same fire. The parts guy should provide all the parts necessary as it was his mistake unless you identified the motor as an outboard.<br /><br />Is the stator burned up too?
