bobnteri@optonline.net
Thread starter- Joined
- May 22, 2005
- 13
Hello all,<br />Have an older 4hp Evinrude Deluxe. It starts fine but will only continue to run if the choke is fully closed. I have changed the diaphram in the pump and have disassembled the carb (jet and needle seat are not clogged, float & valve work). Bulb and connectors do not leak. I can hear fuel running into carb when I pump bulb before starting, the buld stays hard after starting, it does not suck down. I did not buy a fuel pump assembly I put in the diaphram kit. Any suggestions would be greatly appriciated.<br />Thank Yyou
