Question about rebuilding carbs
Bradg
I have a 1982 70 hp Johnson Model# J70TLCNB<br />I would like to know what kind of job it is to<br />rebuild the carbs? I do have some mechanical<br />abilities but have never tackled a carb. Is there<br />any special adjustments needed once the carbs are<br />put back on? I did purchase a factory shop manual this winter to help me.<br /><br />Thanks
Xcusme
Re: Question about rebuilding carbs
Don't let a carb rebuild stop you, it's not a difficult job. Follow the carb removal info from the manual if needed. Disassemble carb, remove any plastic parts, soak in cleaner, spray all passages with carb cleaner, blow dry with compressed air. Replace fuel inlet needle valve, float (if supplied), and gaskets/packing . Adjust/check float level.<br /><br />If it helps, take digital pics at each step and /or take notes. Lay out each piece removed in order. Assemble in reverse order. Don't over torque bowl screws (crushes the gasket). Don't use any gasket sealer on gaskets. BTW, depending on what brand of rebuild kit you buy, there may be 'extra' parts in the kit. Your kit may contain parts for similar carbs, so don't freak, it's normal. If you have questions, post back to this thread. <br /><br /><br />Re-install carb and make needle settings per the following info.<br /><br />Depending on which carb you have, pick one of the following.<br /><br />(Carburetor Adjustment - Single S/S Adjustable Needle Valve)<br /><br />Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.<br /><br />Start engine and set the rpms to where it just stays running. In segments of 1/8<br />turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to<br />respond. As you turn the valve in, the rpms will increase. Lower the rpms again to<br />where the engine will just stay running.<br /><br />Eventually you'll hit the point where the engine wants to die out or it will spit back<br />(sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4<br />turn, you'll find the smoothest slow speed setting.<br /><br />When you have finished the above adjustment, you will have no reason to move<br />them again unless the carburetor fouls/gums up from sitting, in which case you<br />would be required to remove, clean, and rebuild the carburetor anyway.<br />--------------------------------------------------<br />(Carburetor Adjustments - Two Adjustable N/Vs)<br /><br />Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow<br />speed = seat gently, then open 1-1/2 turns.<br /><br />Setting the high and low needle valves properly:<br /><br />NOTE: For engines that DO NOT have a shift selection, obviously there is no<br />NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low<br />speed needle valve adjustment.<br /><br />(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to<br />full throttle. In segments of 1/8 turn, waiting for the engine to respond between turns,<br />start turning in the bottom high speed needle valve. You'll reach a point whereas the<br />engine will either start to die out or spit back (sounds like a mild backfire). At that<br />point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the<br />smoothest setting.<br /><br />(Low Speed) Slow the engine down to where it just stays running. Shift into neutral.<br />Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few<br />seconds for the engine to respond. As you turn the valve in, the rpms will increase.<br />Lower the rpms again to where the engine will just stay running. Eventually you'll hit<br />the point where the engine wants to die out or it will spit back. Again, at that point,<br />back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed<br />setting.<br /><br />When you have finished the above adjustments, you will have no reason to move<br />them again unless the carburetor fouls/gums up from sitting, in which case you<br />would be required to remove, clean, and rebuild the carburetor anyway.<br /><br />--------------------<br />Joe (30+ Years With OMC)
OBJ
Respectfully to Xcusme...there are no needles on those particular carbs, just fixed orifices. Brad, follow the syncronization procedure in the manual after the rebuild.
Rugerman
I'm gonna show my ignorance here and ask how does that work when you have to rebuild 3 carbs on the same motor?
Bradg
Thanks, I will give it a shot in a few weeks, the boat is still in storage 90 miles away. The darn temps are still falling below 0 c(32F) at night here.
Rugerman
Perhaps I didn't ask the question correctly. After you rebuild each carb, how do you adjust all 3 once they are reinstalled? If you experience bogging, how do you know which carb to adjust? I hope I asked this question more clearly this time.
