ross patti
Thread starter- Joined
- Mar 15, 2005
- 157
Re: 1976 johnson 35 surging
Hey fireman & crappie_fan,<br /> A well deserved kick in the xxx .Looking back,I have been guilty of going off in every tangent [and still no result ].<br /> The NGK's finally arrived today. I put them in just now,but I have'nt taken it on the water yet , but in the interest of giving you guys every bit of info. possible...<br /> Since changing the points & condensers,I've used it once,and started it maybe 4 different times.The top plug was coated in a dry,black carbon like coating over the whole firing end. The bottom plug had an even coffee coloured finish to it. Remember,they used to both be totally wet fouled before.<br /> Also,I did firemans coil-swap [sorry c-fan ],and it still cut out when I took the bottom plug lead off.It only ran rougher,but still ran when I took off the top lead.<br /> I also did the spark jump test,and the spark I got from both leads was nowhere near the "strong blue flash ".It did not "snap "<br /> In fact,after hearing all these descriptions,the spark I got from both leads was pretty weak.<br /> I hope this lot gives you a clearer idea of what we are looking at.Also remember that I put in the new NGK plugs before all these tests.<br /> In short crappie_fan ,there 'aint no bolt of lightning at all. But don't you go anywhere ,I like you fiesty people.Shows conviction.And God knows I need persistence here!<br /> So there it is.I hope this new info leads you closer to what is bustin' my things. Thanx again,
