nabeel.alsalam
Thread starter- Joined
- Jan 4, 2005
- 37
I'm still looking for the reason my 1991 Johnson 40 hp won't idle. <br /><br />I can keep it running by keeping the fast idle lever up and pushing the primer every 2 or 3 seconds. I've tried richening the mixture and that seemed to work when I was running the engine on the muffs, but when I put it in the river yesterday, that did not help.<br /><br />There is a thermostat in the engine, but can this behavior be caused by a thermostat that is stuck open? How often does that happen? The water is 40 degrees right now.<br /><br />I have the carbs off again and this time I've remove the core plug. The passages and clean and clear. I've followed the link and sync procedure in the OMC manual to the T. I've checked that the spark will jump 7/16". The VRO seems to pump lots of gas and the pulse limiter was fine.<br /><br />Thanks.
