How much will a whales tail help a 25hp?
smittyCrappie
my boat skips along at about 29mph with me in it alone but when my son goes with me it won't pick us up enough to get going. I have a tail but never tried it. Will it help get our big butts out of the water?
JB
Re: How much will a whales tail help a 25hp?
Yep.<br /><br />Good luck. :)
G DANE
29 mph with a 25 hp is very fine, i never had my 16' above 28 with my 35 hp. Your setup is just fine.
WillyBWright
Since you already have it, try it. But I'll bet you lose a few mph. You never know if it will help or hinder until you bolt it on. I think you'd have better results finding a prop with a smaller pitch. It never hurts to have more than one and a prop for speed and a prop for power are the most practical combination in most situations.
smittyCrappie
Originally posted by G DANE:<br /> 29 mph with a 25 hp is very fine, i never had my 16' above 28 with my 35 hp. Your setup is just fine.
My boat is only 14.7'and light for fiberglass. I was suprised at my speed alone. I guess I will find me a power prop too.
llfish
Drag will slow you down some.
umblecumbuz
Wondering if your boat, being small and light, is tiller steering, or remote? In other words, does it have all the weight at the stern?<br /><br />Sure, a fin on the anti-cavitation plate will be a big help, but it has several disadvantages. The fin angle is tied to the propellor angle because both are fitted to the same leg. Fins often work better with slight negative trim, and this means that the propellor will also be operating ‘out of square’ with the water. Additionally, because the fin is central to the hull, it cannot provide optimum port/starboard stabilisation of the boat, as trim tabs can. As it does not follow the deadrise angle of the hull, it is also a permanent additional source of underwater resistance. The enlarged horizontal surface of the fin can also cause the boat to be less responsive in turns.<br /><br />The most effective answer is to keep propulsion and trim functions completely separate. The function of the propellor is to drive the boat forward, and it can only do this with maximum efficiency when it is at right angles to the water. Obviously if you can fit tabs instead of a fin, you'll get even better response.<br /><br />End of commercial.
