johnson 88hp 1995
mrose
I am having trouble with it not holding idle, runs great when going. When throttling down to go to reverse or from reverse to forward, when goes to nuetral shuts right off. Thanks for any help !
D
DJ
Guest
Re: johnson 88hp 1995
mrose,<br /><br />We need a litle bit more description as to what is happening.<br /><br />1. When was the last time the carburetors were rebuilt? Never? You're overdue.<br /><br />2. "Synch & Link? performed?<br /><br />Manuals available here.<br /><br /> http://www.outboardrepairs.com/manuals/
DHPMARINE
mrose,next time you do this,try pushing the key in to 'choke' the motor.If it doesn't quit,your motor maybe running lean and need the carbs rebuilt.<br /><br />DHP
magic8ball
I also had this problem and found that on the throttle linkage there is a small round roll pin or tab that holds idle open. On this pin is plastic sleeve, mine was worn off and not holding throttle open enough. I just installed a small rubber hose on this pin and idles fine now.
tfbrown1270
Magic8ball......I'm having similar problems...is there any chance you could post a picture of your solution!
tashasdaddy
guys i have an 88 spl your low speeds jets are either clogging, or your idle speed screw is set too low. if your carbs have not been cleaned and rebuilt with a rebuild kit. they are overdue. proper maintainance, means a proper operating engine. i love my engine and have never had a problem, other than dirt doppers clogging the vent line on the built in tank.
