Correct oil for 115hp OMC seadrive
WaterOtter
howdy all. i just picked up a 1984 19' Renken <br />with a 115hp OMC seadrive and i was wondering <br />what type of oil to use for the fuel mix. i read <br />a post on here that said i could use auto motor <br />oil since it's a 4 banger but just thought i'd <br />double check that info before i toss in 10w30 &<br />create a problem. i'll have a few more Q's for ya<br />after i find the bugs... :D <br /><br />TIA
walleyehed
Re: Correct oil for 115hp OMC seadrive
I hope yer jokin' about 10W30.......<br />The 115 seadrive requires 50:1 TC-W3 2-stroke outboard oil ONLY.......16oz oil to 6 gal fuel.<br />It's a 4 banger because it's 4 cylinders, but 2-stroke...it's not a 4-stroke.<br />Good thing you came here before trying auto oil.... :D <br />Welcome aboard.<br />I would highly recommend a water pump change and a new set of sparkplugs (Champion QL82C's).
WaterOtter
thanks guys, i guess i'm showing my newbieness <br />with outboards.. :D . i assumed 4 stroke & 4 <br />cylinder was interchangable. i got the auto oil <br />from this quote in the FAQ section..."Four stroke <br />outboards are a whole different story. Again, <br />users should stay within the limits set by the <br />warranty. Automotive oils are generally suitable"<br />good thing i don't do anything until i'm <br />absolutely sure i'm doin' it right. (well, usually :D )<br />i did a 30 second test run this morning with the <br />fuel still onboard & she fired right up. i bought <br />the boat/motor from an outboard repair guy & <br />he 'said' he kept her in good repair (& it looked <br />like it too)<br />thanks for that link to the manual, i've been all <br />over town trying to find one & all i was getting<br />was the sales pitch for a new motor..
WaterOtter
hmmm, i just checked out the motor for the <br />serial/model #'s to get the manual & it says to <br />use champion plugs # L77J4 & not QL82C. <br />do you guys know where i can go online to verify <br />my HP? (it's no longer on the engine cowling). if <br />it helps the model # is 2BBLCRA & the serial # is <br />J807026.<br />thx
Dhadley
When you fired her up this AM did you have the flushette hooked up? (Was water getting to it?)
WaterOtter
yes, i had water coming out of two small holes in <br />the lower unit with just the water pressure. i <br />didn't want to leave the helm in case it kicked <br />into gear, so i still need to check it out to see<br />if the water pump is working. that's about to<br />happen now that my little helper is home from work.
walleyehed
L/QL77JC4's are fine, but the QL82C is the updated plug recommended for these V4's and a few others.
Solittle
WaterOtter - The hp rating for the SeaDrives is elusive for some reason. My 1987s are 110 hp per the OMC shop manual. I can't speak to the 1984s. I would suggest that you get the parts catalog as well. The diagrams are excellent. By the way for mine there were two different shop manuals. One for the model with hydraulic steering and one without. Not a big deal but I got the one without and of course I have the hydraulic steering.
WaterOtter
SoLittle, ya, i'm finding that out. i talked to <br />the tech guy at the link you posted & he's telling<br />me i may have either a 1.6 or 2.0 liter engine <br />with either a 120hp block or a 140hp block (??)<br />i should know more today...<br /><br />p.s. i did the second test run last night & the <br />water pump appears to be working fine. (yay!)
Dhadley
Your tech is a bit confused. A 1.6 liter (your motor) is a crossflow. A 2.0 is a looper. A 120 block is a looper. A 140 block can be either a looper or a crossflow. 120 and a 140 looper blocks are identical.<br /><br />Just get the manuals for the model number you gave and you'll not go wrong.
GatorMike
Ensign
I had an 89 1.6 liter. At first I thought it was 120 hp but later found out it was 110. I'm not sure it makes much difference unless you get one of those repair manuals that covers Johnson/Evenrude/OMC several models and years then you probably need to know the hp. Anyway it is a crossflow V4.
Solittle
My 1987s are 1.6 liter crossflows @ 110 hp.
