FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
All crank case to cylinder nuts and bolts are to be 220-240 in. lbs. or 18-20 ft. lbs. The scocket head or Allen type screws are the same as the cap screws. Start with the center scoket screws. If you do not have a manual for this procedure,I strong recomend you get one. You really need to understand what your doing here before you start.
Thanks for the advice, I posted last night that I was using a manual and it said to tighten those bolts to 5 LBS, and that just seemed too little. This is why I wanted to check with the experts!
Sorry for my lack of knowledge (and this is due in part to a poorly written manual) but the flange bolts are these 10,11 bolts on the outside of the cover? say, 12 MM? Thanks.
