check vales into each cyl
dcolpitts
1986 140hp rude, I have a broken check vale going into 1 cyl, do these thread out or pull out and how to reseal, as well as how to purchase 1. thanks in advance.
OBJ
Re: check vales into each cyl
If it has a hex head below the nipple, it screws right out. PN 392988...'bout $12. Are we talking about the ones mounted on the intake manifold?
dcolpitts
this one sits on the the cyl block going to cyl #3 I believe its for the recirc system OBJ.
OBJ
Ok...I know which ones your talking about and I can't find a part number for them...I usually find a one laying around the shop..I've broke a couple to. The fitting is just a nipple and it's a press fit. I don't think there is a part number for them unless one of the other guys know what it might be. I'll take a look when I get to the shop and see if I might have one laying around.
dcolpitts
Thanks OBJ, I'm almost finished with this rebuild and found the broken nipple. I think the nipple was broken at the machine shop. do you have a starboard head for 1986 140 loopper? Thanks again
dcolpitts
does this fitting hanve a check valve or a screen or it is it just a port to the cyl.
Dhadley
The part number is 327706 and its just a straight thru nipple. No screen or valve.
OBJ
Where'd ya' find the part number Dhadley?? I'm bout to go blind lookin'.
Dhadley
A secret personal file that no one can look at.<br /><br />Or you can find them on a commercial looper. I looked at a 93 125 I believe it was. Its funny how some parts show up in the commercial parts books and not in the recreational books.
OBJ
Thanks Dhadley....gee....I hope the hired henchmen aren't going to pay me a visit now... :eek:
Dhadley
Naw, admirals have clearance. Especially ones in charge of rears and vice.<br /><br />Never really paid much attention to my rank before. How do you suppose I got hooked up with vice? I wasnt that bad in Vegas!
dcolpitts
Thanks Dhadley and OBJ for the great effort! If you guys had to work at finding the part # you can imagine my frustration. Thanks again guys great job.
Dhadley
Youre very welcome! Let us know how you make out.<br /><br />Good luck!
cowboyup
okam,<br />are these the check valves your referring to? there's a 90 degree fitting pressed into the back side on each of these check valves that connect the recirc. lines. 3 of my check valves don't work, as i checked them with a syringe and alcohol. My 90 fittings are o.k. though. How did you get yours out? I used a small 1/16" punch through the brass insert to puch the 90 degree fitting out. Then i was able to punch the brass fitting out by placing the puch where the fitting i just removed was. it worked on the first one, so i thought i'd stop here and ask your (or anyone's)opinion on the process.
dcolpitts
Hey, the check valves are in the intake manifold and will be screw ins. the nipples in the clys are just pressed in and just have a jet inside the fitting. I remomoved the cyl. fittings by tapping the fitting with a screw driver at differant angles then pulled them out with vise grips, very easy. I had 2 other nipples on the cyls that were clogged, it took carb cleaner and air commpressor to free those up, be patient it takes time. Good luck
cowboyup
thanks for the help. I had to replace one of my check valves on my manifold too. just couldn't seem to unclog that tiny screen. I tried alcohol and compressed air, but to no avail. thanks again for the tip on removing those brass inserts. Did you coat the new ones with anything when you re-inserted them?
