Re: boyesen power reeds
With these composite reeds, you do not want a lean-fire spit back ( back-fire) The flame from the back-fire will damage the reed. These reed's have been used in performace engines, (racing) for quite some time. Beside's the performance gain, if the reed fails at these elevated rpm's, it will pass through the engine with little, or no damage compared to a stainless steel reed. Those career mechanic's should know this. If you go with these reed's, jet on the rich side of the carb. idle circuit to prevent the low idle spit back. These reeds are probably the best performance gain for the money. I don't know what your Baja weigh's, but a 115 properly set up should perform guite well. A jack plate, prop, and set up will give you the best gain. $500 does'nt give you much to play with. A OMC Raker prop, (and that would be my choice) will eat up that)
