FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Hi, I have a 1976 200hp Johnson, it won't start, starter doesnt do anything all I get is a click, batteries are new and the starter was rebuilt about 2 months a go. Any help I will really appreciated.<br />Thank you
1. New baterries dos not mean they are charged.<br /><br />2. Check every battery to engine connection, that includes the connections on the engine end. REMOVE each and clean them.
Hi, I jump the starter and it start really good, however if I use the key switch all I get is a click, any ideas, does the solenoid had to do anything with that click? <br />Thank you
test or replace start solenoid most likley the cause<br />if you have a voltage tester or light check for voltage on big red wire coming in yellow/red wire while trying to crank big red wire going to starter also check black wire to ground
