evinrude parts
garyschneider
I am looking for a cylinder head for a 57 lightwin 3. Also any sources for other parts would be appreciated.
Paul Moir
Re: evinrude parts
Great engine there.<br /><br />If you don't have a local outboard junkyard nearby, the next best place to go is Twin City outboards<br />Why do you want to replace the head? If you stripped a spark plug hole, then simply get a heli-coil installed. It's less expensive, and you get a stronger thread than the original aluminium ones.<br /> <br />Other parts, like coils, points, waterpumps, impellers, gaskets, carb rebuild kits, etc, etc are available from Iboats (use the parts finder in the top right corner), NAPA autoparts, various other places online, or your local Johnny/Rude dealer. Parts for that engine are pretty inexpensive.<br /><br />Hope this helps!
garyschneider
Re: evinrude parts
Thanks paul<br />It has a small area of corrosion and I am concerned when I reassemble it it will leak. <br />Any idea of torque specs and pattern for the head? Thanks.
