Removing Tilt Trim Pins
Greg Lawrence
I have a 1991 OMC tracker pro 60 hp. Tilt trim motor is totally rusted though into the motor, does nto work. Removed the four snap rings that seem to hold it all in, the pins that go through the bottom and the tilt cylinder at the top will not budge, have been using PB and a hammer with no results. arent these pins supposed to move?
D
DJ
Guest
Re: Removing Tilt Trim Pins
Yes they are, keep working, patiently, the way you have been.<br /><br />You can CAREFULLY try heat around the castings the pins go through. Be aware, you will destroy the paint where you apply heat.
Greg Lawrence
ok, how about a bigger hammer? i used a bigger hammer on my steering tube when i couldnt get the steereing cable to move either! hahah
Greg Lawrence
ok got the top one out, bow the bottom is going to be a little harder i think.
