pistons
papasage
1974evinrude to put 1976 pistons in it the book shows a wrestpin on the 76 is 3/4 and the 74 is 5/8 . acording to the parts manul the wriet pin berring wp15-1 will let the 76 piston work in the 74 rod . am i reading that rigt ?
Dhadley
Re: pistons
Are you looking in the Pro Marine catalog?<br /><br />Are you working on a 3 cylinder 70hp E/J?<br /><br />Lots of guessing (on my part) going on here.....
papasage
Re: pistons
this is 1974 70 hp. 3 cylinder . looking at several parts sites on line . the 74 and 75 has different wrist pins than the 76 and newer . the wristpin berrings kit as i understand it adapts the 5/8 to 3/4 so the 76 will work on the 74 rod . OUTBOARDPARTS.COM .this is the site i found the parts on <br /> <br />papasage
Droll
Re: pistons
Don´t know, but do read it the same way .<br /><br />According to the Wiseco katalog ( Pdf katalog ) , you can use 3115PS ( 3.00" looper ( page 3 )) on all engines from 1974 > 1985 ,but with the bearing kit #B1029 on the 1974-75 .<br /><br />kit #B1029 = wp15-1 ? ( only different brand ? )<br /><br />
Dhadley
Re: pistons
The B1029 and the WP15-1 are the same thing. The B1029 is from Wiseco and the WP15-1 is from Pro Marine.<br /><br />The kits allow you to use the 1976 3.000" piston on a 1974-75 rod. You can put the 1976 rods in your 1974-75 motor and do the same thing.
papasage
Re: pistons
the 76 rods wer left in the weather and has rusted by the preavious owner all i have is pistons . papasage
Dhadley
Re: pistons
Ok, if you have to get rods anyway, I'd opt for the 76 and newer. Then you dont have to mess with conversion bearings.<br /><br />BTW -- rods from a 56 cid 3 cylinder are different. You have to get rods from a 49 cid 3 cylinder. The casting number is on your rusted ones.
papasage
Re: pistons
i have rods for the 74 and pistons for 76 . i just have 74 bad pistons and rusted 76 rods and wrist pins
