Re: Sizzling Battery
Hello, Sounds like high resistance and corrosion played a part in your major meltdown. Corrosion in battery terminals and wires will cause the symptoms you are experiencing. I saw a battery once where the negative terminal was so corroded internally that the terminal snapped off of the battery with just a slight tug. I would replace the battery and replace or repair the cables. If they look old and dry cracked 86 'em, if the terminal ends seem to be the only problem crimp or solder new ones on and follow up with some heat shrink tube over the soldered areas. Also check the other connections on your O/B for corrosion as well. The starter terminals, solenoid terminals to name a few. Put everything back together with a dab of silicone electrical grease and tighten it up good and you should be all set.
