water leak
Johnson110
hello i have an 1986 110 johnson, put water pump impellar in motor at start of season, just today motor started to leak water around upper collar, is there a gasket to replace? can i wait till end of season to pull lower unit off for inspectionw/o damage? motor is running at normal temp, also the motor is used in salt water docked. i was concerned that water leak would get to drive shaft and fused to powerhead if thats the case then i will pull boat out of water to do repair, but whats the leak from? it just started. thanks for any input!
Johnson110
Re: water leak
the two relief holes out the back of the motor, to the side of that housing water leaks out when motor is running. thanks for any help
