same gearcase?
woodboatguy
i have a 1964 evinrude 90hp with electric shift ( selectric)that needs repair. will a gearcase (selectric)from a 1967 80hp evinrude work on my motor?
Droll
Re: same gearcase?
I belive you can use parts from:<br />75 HP - 62 > 65<br />80 HP - 66 > 67<br />90 HP - 64 > 65<br /><br />NOT 100 HP -66 > 68 ( bigger ++ )<br /><br />I have just rebuild my lower unit , what was wrong with yours ?
woodboatguy
Re: same gearcase?
when i was replacing the bearing for the drive pinion i must have dropped a pin down the hole without knowing.the reverse gear lost 1 tooth and the drive pinion lost part of one. it looks like one of the springs is a little stretched also. <br /> i found the new parts locally but they are very expensive, gear $200 and pinion $268 so iwas hoping to use the 80hp gearcase for parts or replacment if it is in good enough shape.
jimmbo
Re: same gearcase?
The 100hp should bolt on as a complete unit though, the midsection of the engine is still the same. The 5 inch extention is different but should replace the one on the lower hp units.
