'84 1.6l OMC Sea Drive (ie 4 cyl., 115 Crossfow)<br /><br />I noticed that I have a slight oil leak at the plastic 90 degree fitting at the lwr cowl.<br /><br />Current fitting is kinda "mushy" when wrench is applied so so I wasn't able to tighten. May be able to turn a litte to tighten with channel locks but I don't think I can get a full 360 on it to keep 90 deg fitting in current orientation.<br /><br />Leak is only slight (didn't notice any leak when oil primer bulb is squeezed) considering sealing externally with RTV(?) or pulling fitting and replacing with brass straight fitting. <br /><br />Has anyone expierecned similair problem or replaced plastic with brass. Plastic fittings seem like a poor design choice. <br /><br />Any feedback welcomed.<br /><br />Thanks<br /><br />RK
