FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I read somewhere that I could cut a gasket out of a cereal or pizza box and use permatex to seal it. I need a gasket for my thermostat housing on a 1965 Evinrude 18hp. Is this a good or bad idea?
Good if it works, bad if it don't. Really bad if it deteriorates and causes a clog, then an overheat, then a seizure. If your gasket is too thick, stat wont seal and do it's job. Seems alot to risk to me!!
It can work, but why not get some gasket material from an auto supply store and make it out of that? Then you'll have much better binders than the cereal box has.<br />I have a roll of paper gasket material, a set of various sized punches and a common hole punch to make gaskets on the fly. They always work well. A supplimental sealant (permatex) is often a good idea, just not around intakes like with manifold or carb gaskets.<br />A trick for transfering the pattern to paper is to cover the surface with paper, and rub the paper with a peice of solder. You get a nice outline of the mating surface that way.<br />Good luck!<br />EDIT: angus has a very good point. Whenever you make your own parts, you must be responsible. I once made a quick test head gasket for a 3hp (no metal ring), but forgot to put the coolant passage holes in it!
I can buy a roll of gasket material at the local NAPA Auto store but I'm unsure of the thickness. The old gasket is so deteriorated I can't use it as a guide. How thick should the material for the gasket be?
Paul, Its information like that which makes this forum such a valuable resource. I will go to NAPA tonight and buy the proper material and cut my own gasket. Thanks so much.
"The old gasket is so deteriorated I can't use it as a guide"<br />If you don't cut the gasket exactly you may cause damage(eventualy)to your motor.I'm sure there are holes(water passages) in the gasket,etc. in key area's,so if what you say above is true...Is there a Johnny/Rude dealer near you?If not,why not order one online?www.maxrules.com is another source for older parts.
