FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
i was removing one of the 4 bolts that attach the lower unit to the exhaust housing. i removed 3 of them but the 4th broke the head off the bolt, should the lower unit still slide off?
Re: oh no 110 johnson bolt head broke on lower unit
If i'm thinking of the right year.<br /><br />There are five bolts on that lower unit.<br /><br />It should be by the trim tab. If the head completly sheered off the bolt once you get that fifth bolt off is should drop out. Make sure all the conections are loose like the shift rod. <br /><br />Also there is an o ring on the top of the drive shaft sometimes it will take a hefty tug to get it to break loose.
