McGR
Thread starter- Joined
- Jun 19, 2004
- 668
I have spent virtually all my spare time over the past month ressurecting an old '76 Johnson '85hp. The motor is looking good and should be ready to run like a clock. Today (father's day) we were planning on taking the motor out for its maiden voyage. In preparation, I filled the lower unit with fresh lube last night. By the looks of things everything was on track and I'd soon be basking in triumphant glory. Instead, I was shocked this morning when I went to the garage to find a pool of gear lube below the motor. This surprised me, as I had replaced all the seals during my restoration project. Anyway, I eventually located the source of the leak. Fluid is coming from a factory machined hole on the left/port side of the gear housing. This hole is below the cavitation (anti-cavitation?) plate approximately opposite the vent plug on the starboard side. I tried pumping more fluid into the unit to see the results and found that,sure enough, as I pumped lube would exit the hole. After reviewing my parts and service manual, I'm completely perplexed as to why this is happening and what the function of this hole is. The hole is located below the seals and gaskets on the upper part of the lower unit and obviously above the prop shaft seal. So, what is its function?? I'm tempted to tap the hole and drive a set screw into it. Though, somehow, I've got a feeling this is not the generally recommended repair techniue for this problem. Anyone who knows what is going on, please let me know so I can possibly still experience "my moment of glory" soon.<br /><br />Thanks in advance...
