dutch oldie seahorse looses power after 20 minutes
ckwantes
got an old johnson seahorse 2hp (70-ies) from a friend. It starts (too?) easy. First no problems. After 20 minutes, opening the gashandle results in loosing power (like running on a hill with car). When putting the engine "in free" (no rotating prop) the problem fades away for a few secs, after putting egine in forward (rotating prop) the problem returns. The 2 bougies (ignation) look quite dark. Does anyone have an idea?<br />Thanks
JB
Re: dutch oldie seahorse looses power after 20 minutes
Hi, Chris.<br /><br />Welcome to iboats. :) <br /><br />Some of what you say is confusing because it doesn't sound like any 2hp Johnson I am familiar with.<br /><br />Please give us the model number off of the mounting bracket plate.
rwise
sounds like it may not be keeping enuf (enough) fuel in the carb. just a thought.
ckwantes
excuse me.<br />i was a bit confusing:<br />it is a 2 stroke, 2 cilindre, SIX HP engine (or 5, i dont know exactly). This wil clear a lot. I can check the serial number, but perhaps this explenation already explains a lot.<br /><br />Yesterday did some testing.<br />Turning the central lean-rich-screw till it was totaly closed (perhaps the fuelinput was too rich). Didn't change anything at he motor. When a turned and pulled it out, I saw there was no rubber thing on the end of the "needle"/conus (as was told to me as it should be). Could this be the answer?
ckwantes
serial nr: <br /><br />6 RL 720<br />B 20868
rwise
if you can turn the adjustment for fuel air mix completly closed, and it makes no differance in the way the engine runs, I would clean and rebiuld the carb! Dont know about there, but here a kit runs about $20. When I done the carb on my 1958 35hp I found a rubber washer inside the carb that was crumbling away and stopping up the main jet! <br />I could br wrong but I think the rubber for the needle will stay in the carb when the adjustment needle is removed.
ckwantes
today I showed the engine to a mechanic: turns out to be water in the cilindres too. The lean-rich screw happens to be the adjustment for the stationary-fuelsupply. So i indeed closed this one, but kept giving fuel by keeping the gashandle above stationary rpm. So at least I didn't had a miracle in my hands. I'm afraid this oldie is going to be terminal... Or don't you agree on this one?<br />thanks anyway for the response..
