19 Foot cruise Craft with 115 hp johnson wont plane
gty2k2000
Re: 19 Foot cruise Craft with 115 hp johnson wont plane
thanks very much on the tach help i have found the right wires hanging out of my control box. bu tshould i get a new tach and should it be a johnson evinrude product as well
gty2k2000
my rectifeyer is looking pretty ugly under the hood will that affect the tach if not working properly?
kesso
I would suggest buying the most economical Tach possible; I purchased a Mercury Quicksilver tach from Ebay and it works fine on my Johnson.<br /><br />Is the rectifier-regulator still working, can you still charge the battery and produce 12V for onboard electronic equipment?
gty2k2000
dont know ill have to look into that
gty2k2000
hey you guys i finaly moved that manual trim tab pin me and my dad took her out and opened her up and hit 32 mph and there were pretty rough sees
tengals123
Master Chief Petty Officer
a perfect example of how important trimming a boat is. Just think of your fuel savings. cheers
G. Arruda
I'm having simular problems, Biloxiriver... was this water in the hull problem water trapped in the walls, or just holding water in the bilge. Is it possible, and how I do you know if water is trapped. <br />Thanks
