Re: 1957 evinrude bigtwin 35
What happens when the gear lever is in the neutral position? it wont shift unless motor is shut off, and it still churns alot of water.<br /><br />you're propshaft had no detent ball and spring to 'click' your shift dog into forward, neutral, and reverse right? So the only thing to set it to one or the other is the lever and spring arrangement that works on the shift handle right? right.<br /><br />when you freed up the shift dog, it slid easily on the propshaft right? right.<br />you may have to remove the power head to straighten out the bellcrank underneath it.<br />i sure the hell hope not<br /><br />It's not getting hung up in forward and then flying over to the reverse gear right? dont have a clue.<br /><br />im not mechancically enclined, im very surprised i got as far as i did today with the lower unit, i was hoping it would be a easy fix, like i put the dog gear in backwards or something, as soon as this is lined out im gonna try changing the water pump, and then rebuild the carb, thanks for the reply and suggestions
