Re: Proper lower unit oil for 1973 135hp
Got some answers. My service manual is for model 135ESL73. There is only one geartrain exploded diagram, it s called power shift II. The call out for lube is OMC sea lube gearcase lubricant and says also"previously OMC type c lubricant". In looking at the exploded diagram, I compared with a CLymers manual because Clymers has a diagram for a "Mechanical " and another diagram for a "hydro-mechanical" gearcase. THe 135esl73 is clearly a Hydro-mechanical type gearcase primarily because it has a gear type oil pump, while the purely mechanical doesnt have the oil pump. So, I also now have the question of what modern brand product should I be using in the lower unit? Again, have been using high vis with no problems for 3 years. It is one great running motor.
