what size prop??? 225 looper
Bogart
I have a 23 foot sea ox I had full gas 116 gallons full bait tank 25 gallons boat did 27<br />knots wide open at 4800 rpm with a 15/1/4 X 15<br />prop! Is this good????????? or should I try somthing else!????<br /><br /> Bogart.
D
DJ
Guest
Re: what size prop??? 225 looper
You're overpropped. It should turn AT LEAST 5500 at WOT.
Dhadley
Is that when you had spark or after you lost spark?<br /><br />Seriously, I'd like to see it closer to 6000. Are you sure its hittin' on all 8?
Bogart
It was before I lost power! now I have no spark!<br />on all 6 cylinders<br /><br /> Bogii.
Bogart
My engine used to get 5500 rpm!<br />would the power pack cause this to go down to 4800rpm before failing????????????<br /><br /> Bogart.
Dhadley
Very possible. <br /><br />Was it a failed pack? BTW -- glad you caught on to the "all 8" deal. :)
Bogart
Dhadley I dont know if the pack is at fault!!<br />I dont know how to check it I will bring it in tommorow and let u know!!!<br /><br /> Bogii.
