steviecops
Thread starter- Joined
- Oct 3, 2003
- 585
I've removed my head cover to replace thermostat, but one of the bolts broke in the cylinder head. The stud is almost flush with the head, as you can see from the picture. Can I get someone to mig weld a nut onto this so that I can remove it?<br /><br />A neighbour has a mig welder, but doesn't fancy his chances of success. He says that he's scared that the heat from the welder might melt the aluminium head. Is it safe to use this method that close to the head? What you can't see from the picture is the engine cowling, which comes above the broken stud, so drilling it out isn't an option.<br /><br /> pictures <br /><br />Just as a matter of interest, the second picture is of the old thermostat alongside the new one. Out of curiosity, I tetsed the old stat and it worked fine, but as you can see, the little disc has come off, so there was nothing to stop the water flowing through the stat! There was no sign of it antwhere under the head cover, so it's either rotted away, or it is somewhere in the cooling circuit. I hope it doesn't cause any problems!<br /><br />Any advice on the broken stud would be appreciated. I was hoping to spend tomorrow getting it out.<br />Thanks<br />Steve
