'83 Evinrude 15 tank vent.
Batchawana
Should the remote tank on this motor be vented? There's a big sigh whenever I open the cap. I've seen a little brass vent that you could open on some older tanks, but this one seems to have no venting provision.
D
DJ
Guest
Re: '83 Evinrude 15 tank vent.
Batchawana,<br /><br />If you have an ORIGINAL OMC tank (one hose type), they are self venting.<br /><br />Aftermarket tanks, typically, do not. They usually have a vent screw on the cap.<br /><br />If you are having fuel starvation problems, just loosen the cap and see if that cures the concern.
troykx
Hello there ,, I had just bought an old Evinrude Fastwin 18hp, Does anyone know what type of gas tank do it use..Does it require an pressurized tank?
Thankx
Troy:
bktheking
Thankx
Troy:
You are tagging onto a 6 yr old post. If it has the 2 line connector on the motor then yes it does need a pressure tank.
1946Zephyr
Thankx
Troy:
That depends on the year. I believe it was 1960 when they changed over to the single line system. The best thing to do is check your model number and check back with us and also look at the connectoron the motor and see if it has one or two connectors on it.:cool:
1946Zephyr
Wait a minute. How did that happen?:confused:
troykx
Sorry I forgot to state the year of the evinrude it is a 1957. and it dies have a double connectors,, is the third connector for locking?
Thankx again
1946Zephyr
Thankx again
Cool!! I own the same motor myself. Yes I do believe that is for locking. I have a pretty interesting thread on these old motors. I would say....quite indestructable they are. LOL:D
bktheking
:confused:
Hey BK. How's the arm feeling? ;)
They put a permanent cast on today, i'm awake cause the itch is driving me crazy :mad::mad::mad::mad::
From the connector are their 2 gas lines going into the motor or 1?
troykx
I check the Model and year (1957-motor#15020)listing online. I can't find gas tank, fuel line assembly or nothing for that year. I have a newer yamaha gas tank (non pressure tank)and was wondering if I can just an fuel line assembly for it.
troykx
Yes, there are two lines going into the motor, I thought 1 of them was just a return line(overflow) back to the tank
bktheking
One is feed the other is pressure, you will need a pressure tank or to covert it to pump/single line.
1946Zephyr
No, sorry you can't do that. Yes 15020 is a 57, just like mine. One of the nipples is a fuel inlet and the other is an air outlet. Not sure where you're getting the third one at. it must be some sort of locking deal or something.
Your Yamaha tank would work fine, for one of the newer single line set ups and you changed the connector for OMC. The older twin line OMC set ups are very proprietary and nothing else will work with them. If you want to convert that old Fastwin to a single line set up, then you'll need to install a fuel pump and a new single line connector on the motor. Getting the old twin line tanks can be a bit tough and spendy, usually. I got lucky and found one for 10 bucks, but I was REAL lucky. All I had to do was replace the hose and that was quite a bit more than I spent on the tank.
If you have a Yamaha tank already, it may be just as well that you convert to a single line set up. What you'll need to do is buy a fuel pump for a 1960 or later 18hp and a bypass cover to mount it on and the connectors that go on the motor, by the tiller handle.:cool:
bktheking
Here is the damage Zeph
1946Zephyr
OMG BK!! is that the screws in your arm?? Or is that the screws you you placed on your work bench from one of your projects?
If that's the first, then it makes my arm hurt just lookin at it.
How did this wreck happen? Icy roads?
bktheking
The first one lol , I was on my way back from helping a buddy of mine install a server, I was the passenger in his car. We were 1 minute from home, he pulled a left right in front of an oncoming Chevy Trailblazer doing around 60km/hr. He left the scene with a broken neck (he's not paralyzed at all) and that was my arm damage from hitting the door. The driver of the TB had no injuries. We were in an Escape (I know, I escaped in the Escape lol )
trendsetter240
Ouch! wait..are those deck screws or stainless?..Did they seal it with 5200?;)jk Glad everyone made it out. I was wondering why you haven't been around much this past week or so.
I hate the cast itch..haven't felt it in a few years (knock on wood) but it really does suck! get yourself a coat hanger and straighten it out. Works well for a scratching tool.
bktheking
Its my right arm too TS, I'm still awake from the dreaded itch. I think they used 5200, I'll have to check:D
