brother chris
Thread starter- Joined
- Jul 28, 2002
- 2,063
Okay, I have a 1978 55hp evinrude, and from previous posts, I have already changed the water pump and put the leg back on several times and no water comes out of the "p" hole. <br />After blowing air through the water tube with no avail, I decided to change/check the thermostat. <br />I took the back panel off(12-14 screws), and when I took it off, a red piece of plastic with a raised "x" on each side of it came out where the thermostat is supposed to be. There is a rubber gasket around it as well. It does not look like any thermostat I have ever seen. Even looking at the book, it looks different. Is this the thermostat? <br />I also have to replace the large gasket the goes between the back plate and the motor. <br />Anyways, can anyone tell me if this is the thermostat or not. <br />Thanks in advance.
