"O" ring in waterpump kit?
spike440
whats the little o ring for in my water pump kit? It's for a 1971 Johnson 50. The manual shows it but not where it might go. There wasn't one in the outboard when it was disassembled. There is a groove on the driveshaft up by the splines that engage the powerhead. Could that be it? Thanks!<br />-Spiker
jshigman1
Re: "O" ring in waterpump kit?
thats it most likely, just put iton the shaft and see if it fits. It should be what its for tho. :)
rodbolt
hello<br /> yep thats it.<br /> now take a powerful light and try to find the original one. it may be stuck in the power head. if so it may cause assembly problems.<br /> good luck and keep posting
spike440
Thanks once again for all the help!!
Hooty
Use plenty of grease on the driveshaft splines but do not grease the end of it. Maybe just a very thin coat, no more.<br /><br />c/6<br />Hooty
