Checked with timing light. When it starts missing there is no spark on either plug.<br /><br />What components are common to both plugs that could be the problem? I think I have the TYPE II CD FLYWHEEL MAGNETO with SENSOR COIL can someone confirm this for me? Reading my Selcor manual I think the capacitor is built in to the power pack?<br />My coil is a dual coil, both plugs from one coil.<br /><br />I don't think I can check them like the manual suggest because it runs perfect up to 2k rpm therefore they will test good electrically.<br /><br />Which order of parts would you more experienced guys purchase first? Cheapest to expensive I would think or which is more likely to be at fault? Or at this stage of the game should I just buy the power pack?<br /><br />Thanks,<br />Beck<br /><br />Also any e-mails will be welcomed.<br />Dpb1972@aol.com
