DHADLEY
Don CHICHO
I OWN A JOHNSON 140 H.P., Looper,1987, with Lighweight flywheel, Carbs velocity stacks, 1986 Intake Manifold, RAPAIR Pack, Coils, Stator & Timer, Heads Milled .030", Timing 16 degrees,,Land & Sea Solid Upper & Lower Mounts,<br />Exhaust Releiving, Bob's Machine Nose Cone.<br /><br />I would like to know how to Modify my present Intake Manifold. My TOP RPM is 7,000 , using a Drag 3, Performance Propeller (TIM HACKNEY)<br />13.5X24 in an Allison Racing XR-2002 Boat<br /><br />I'm using in my engine a 95 RON Unleaded Fuel with a Pennzoil 100% Synthetic Oil (40:1)<br /><br />Thanks,<br />DON<br /><br />DonChicho71@hotmail.com
Don CHICHO
Re: DHADLEY
A FRIEND TOLD ME, with .030" SHAVED HEADS<br />I MUST STAY AT 16 DEGREES , USING RON 95 OCTANE GAS.<br /><br />I WOULD APPRECIATED ANY ADVICE, TO IMPROVE MY ACCELERATION & TOP SPEED.<br /><br />THANKS,<br />DON<br /><br />P.S.: DO YOU THINK I MUST STAY WITH 18 DEGREES??
Dhadley
Re: DHADLEY
First, in the intrest of safety, keep a close watch on the port stern bracket. With solid upper mounts in an E/J, the port stern bracket tends to split. The steering gets a little goofy when the motor falls off.<br /><br />What have you done with the jetting? Without the airbox you should richen up by 12 to 15 numbers.
Don CHICHO
Re: DHADLEY
YES, ACTUALLY I DON'T REMEMBER THE #. BUT I RICHEN THE MAIN JETS AND DECREASED THE AIR JETS<br />I THINK A 16 .<br />BUT I NEED TO KNOW IF I STAY WITH 16 DEGREES MAX. TIMING OR I SHOULD MOVE TO 18 ?????<br />USING 95 RON UNLEADED GAS .<br /><br />THANKS A LOT,<br />DON
Don CHICHO
Re: DHADLEY
OHHHH, FORGOT. MAY I STAY USING THE 1986 INTAKE MANIFOLD ????<br /><br />DON
Dhadley
Re: DHADLEY
OK good. We always got the motors to run better/quicker running the airbox but thats OK for now. As long as you are rich enough it'll be fine.<br /><br />Are you still running a 1987 powerhead? IE -- the small bore block?
Don CHICHO
Re: DHADLEY
O.K. BUT, 16 or 18 DEGREES BTDC ????<br /><br />DON
Dhadley
Re: DHADLEY
The catch is to be positive youre running rich enough. If so Go to 18 degrees and test.<br /><br />What spark plugs are you running?
Don CHICHO
Re: DHADLEY
CHAMPION QL78YC, GAPPED AT .030" <br /><br />THANKS,<br />DON
Dhadley
Re: DHADLEY
Keep an eye on the long reach (Y) plugs with the cut heads. Let me know how you make out testing at 18 degrees.<br /><br />Are you still running the small bore block?
Don CHICHO
Re: DHADLEY
YEAP!!!, SMALL BORE BLOCK .<br />CAN I BE ABLE TO ADJUST THE MAX. TIMING AT MY GARAGE ??? INSTEAD OF THE BOAT RAMP.<br />IF THERE ARE A LOT OF DIFFERENCE IN SETTING THE MAX. TIMING ????<br /><br />ALSO, I WOULD LIKE TO USE AN OCTANE BOOSTER, LIKE 104 + OR NOS . ANY ADVANTAGE ????<br /><br />DON
Dhadley
Re: DHADLEY
Once we get into modified motors we really dont adjust the timing with a light. Once you have your starting point, which you do, we adjust it with testing. For every turn of the timing stop screw the timing will change approx 1 degree. Back the screw out 2 turns and test. This should be about 20 degrees. Be careful to start your jetting check at 2500 to 3000 and go up in small increments. <br /><br />I would stick with straight gas and no addatives. I dont like to use cut heads. If you really want to be safe, use avaiation fuel. Its a low lead fuel usually around 100 octane. Or some type of race fuel. Whatever you chose, stick with it. Be consistant. You are getting ready to change everything else.
Don CHICHO
Re: DHADLEY
O.K. . THANKS A LOT.<br /><br />BY THE WAY, I'M SEARCHING FOR AN EVOLUTION MARINE INTAKE MANIFOLD ( NO LONGER AVAILABLE !!!).<br /><br />DON
Dhadley
Re: DHADLEY
The Evolution intakes are pretty aren't they? The downside is that I dont think Marvin makes the reeds that are required anymore. <br /><br />What this manifold does is align the reeds so they are centered in the passages in the front half of the block for better flow. <br /><br />You can do the same thing with your stock manifold. To do this you will need a front half to bolt the manifold to so you can turn it around and look at the reeds as the proceedure is done.<br /><br />Are you running in a class that has specific rules? If so, what are the rules and sanctioning body? OBDA? APBA?
Don CHICHO
Re: DHADLEY
NO RULES. ONLY V4's . YOU CAN DO EVERYTHING !!!<br />O.K., I WILL CHECK THE INTAKE, BUT ACTUALLY I'M USING A STOCK RUBBER COATED REED CAGES, THAT I WOULD LIKE TO BE MODIFIED OR MAYBE, TO BUY A SET OF PERFORMANCE ONES.<br /><br />TOMORROW, I WILL MOVE MY TIMING TO 18 .<br /><br />THANKS,<br />DON
Dhadley
Re: DHADLEY
Marvin is a friend of mine and his intakes really do help. But we've found that modifying (re-aligning) your reed cages work just as well. But his are way cooler looking!! If youre serious about buying one I'll see if I can find mine. <br /><br />No rules, huh? That changes everything. What kind of budget do we have? We just went from making an SST100 powerhead to a Formula II.
walleyehed
Re: DHADLEY
Dhadley is currently trying to find his brain bucket....I can see the wheels turning from here :D <br />G DANE, if yer watchin', take notes!!!
Don CHICHO
Re: DHADLEY
O.K., DHADLEY . IF YOU CAN GET AN EVOLUTION MARINE INTAKE MANIFOLD, PLEASE LET ME KNOW .<br /><br />WHAT'S YOUR OPINION ON OMC'S COILS ?????<br /><br />THANKS,<br />DON
Dhadley
Re: DHADLEY
I'll let you know next week. I'll look this weekend.<br /><br />We never really had any problems with the E/J coils. We ran them over 9K with no problem.<br /><br />Tell us about the fuel syatem in the boat. Are you using an electric pump?<br /><br />So what is the budget anyway?
