Re: 1974 115hp Evinrude cranking speed and spark
I've had the timer bases mess up at low rpm on those "powerpack" ignition in the 1973-77 V4s & I3s (a lot) but haven't had problems with the stators being able to generate enough charge, or the powerpacks being failure-prone for that matter. A failing timer base makes itself known by cutting out one cylinder at low rpms - rev it up a bit and everything's fine. <br /><br />The other problem with those 1973-77 V4s (in my limited experience) is the choke. Unless the flaps close 100% (99.94% isn't enough), the motor simply won't start. Also, the OMC starter solenoids seem to fail a lot, cutting the current so that you thing you have a bad starter motor. <br /><br />Street racing...I feel so bad for kids today not having what we had 30 years ago. Back then, when something hairy pulled in, you knew you were going to see it run hard in a few mintues - maybe for a few bucks, maybe just for fun - but it WAS going to go. These days, if you see a blown Camaro or something, there's a town cruiser right behind it. Not to trash law enforcement - it's just that times have changed. Anything risky is strictly forbidden for your own good. I'll tell you though, get even a mile offshore and you're back on your own.
