Johonson 175 Ocean Pro idle Problem
plus+
hi,<br />one of my 175 idle too high 1500.<br />if any one could tell me to how to lower the rpm?<br />thanks any way to all...<br /><br />SS
JB
Re: Johonson 175 Ocean Pro idle Problem
Moving to JohnnyRude Troubles.
Dhadley
If thats on the flushette and still in Quick Start, thats probably about right. A tad high but close.<br /><br />If thats in the water with back pressure and warmed up (out of Quick Start) thats too high. <br /><br />All this is assuming you have the thermostats in and the linkage is all in sync.<br /><br />Good luck!
angus63
Unless you are familiar with the timing settings and the control cable adjustments, more harm than good could occur. There is no simple throttle position adjustment, but a host of possible reasons for high idle.
