Re: Carb adjustment
There is no high speed adjustment for these carburetors.<br />Slow speed mixture adjustment as follows:<br /> The slow speed mixture adjustment needle is located at top left side of carburetor when looking at it from the front.<br /> Start engine and let it warm up for 3 to 4 minutes.<br /> Make sure engine is on boat in the water in gear at idle speed with nothing restricting movement of boat.<br /> If the adjustment is too lean, the engine will spit back and backfire.<br /> If the adjustment is too rich, the engine will be rough and sound like it's flooding out.<br /> If engine is lean (spitting back) turn screw counterclockwise 1/8th turn. Allow 15 seconds between adjustments. Adjust until engine is running at highest RPM.<br /> If engine is running rich, turn scew clockwise 1/8th...same as above. If engine starts to spit back, yuo're too lean. Back needle out until engine is at it's smoothest.<br /> I've found thatyou can just start turning in until it spits back, and then back it out just a tad until it runs smoothly.<br /> repeat these steps on both carburetors.
