MadeCoolCom
Thread starter- Joined
- Jun 4, 2003
- 76
While I notice this forum is on this subject. I will would like to run this by you all.<br />Ok I put new head gasket on 3 months ago the engine is running good. While I had the head off I cleaned off the top of the pistons and cleaned the head of course also. Now it seems to run better and I just took out the plugs to replace because I been about using this 30- 40 hours of use or 50 - 60 gal of gas i used. When took out the plugs I notice the bottom plug was oil on it but it looked clean.<br />The top plug was dry with a lot of carbon build up. The bottom had no carbon on it or maybe just a little and was brown but hardly any.<br />What do you think about that?<br />##############################################<br /> I don't think it means to much one way or the other I pre mix the oil in my engine 1980 60 Hp Evinrude 2 cylinder. Because the way you turn off the engine etc affect the amount of oil on the plug. If run your engine out of gas that might affect it to which I do if I don't plan using for a couple of months. Also if you shut off engine running fast idle it might affect it.
