Correct trim
John McFarlane
Is there an easy way to know when a boat is correctly trimmed at speed please?
Dunaruna
Re: Correct trim
John, <br /><br />There are some tell-tales that will alert you of incorrect trim such as porpoising, sucking air on turns, rooster tails, really bad fuel economy etc. but IMO it comes down to 'feel' and you'll only get that with time. You can even add gadgets such as a fuel computer that will give you optimum economy.<br /><br />Every boat/motor combination is different - experiment.<br /><br />Aldo
Triton II
Re: Correct trim
Generally when it achieves the highest rpm without any signs of ventilating at WOT. However if the boat porpoises off waves it is generally trimmed too bow high, if it wanders around and the steering gets heavy as the speed increases it is generally trimmed too bow down. If it ventilates in turns or with a following sea it is generally trimmed too bow high. There's no real answer to this question, there are so many variables, but trial and error will soon show you where to trim for whatever the situation. Best of luck. :)
Dunaruna
Re: Correct trim
Yeah but your much more eloquent in your delivery :p <br /><br />Aldo
Triton II
Re: Correct trim
I think perchance you mean 'you're' and 'eloquent'? Confusing this language ain't it but! :confused: <br />Please see question on your carp post.
Dunaruna
Re: Correct trim
Hey hang on a minute, you're not Mr. Browning are you? (my 5th grade english teacher) :D <br /><br />Aldo
umblecumbuz
Re: Correct trim
As has been said - this site is an education!<br /><br />English language only please!
cthru1
Re: Correct trim
Triton II, what is ventilating? Please explain as if I were a child so I can understand. Thanks
Dunaruna
Re: Correct trim
Ventilating is when the prop sucks air - basically.<br /><br />Good on a plane, bad on a boat :D <br /><br />Aldo
Dunaruna
Re: Correct trim
Just my warped sense of humor at work, Ok ok I won't give up my day job :rolleyes:
Triton II
Re: Correct trim
Mr Browning here. For a change Dunarunna has something of value to show and tell the class. <br />Mr Duna?<br />"Ventilating is when the prop sucks air - basically.<br /><br />Good on a plane, bad on a boat :D <br /><br />Well done Dunarunna. You are correct. Next time please remember the full stop (period to those of us who have an American education) at the end of the sentence! <br />In plain English, here's an explanation...<br />The boat's propeller rotates at such a speed and close enough to the surface whereby it creates a boundary layer of air over its blades. It does this because the blade tips break free of the surface and literally "suck in air". Boat propellers, as Dunarunna so eloquently states, are not designed to rotate in air, and the thrust decreases as the rpms rise. Ventilating (also erroneously know as cavitating) is this self perpetuating condition where the propeller spins fast in a bubble of air, next thing you know, you're going nowhere fast. It's cured by lowering the trim or straightening out of the turn (if that's where the ventilation occurred). Ventilating is not good for the propeller but isn't as bad for the motor as many people make out - simply because modern motors have rev limiters and no one in their right mind allows the propeller to ventilate for long. Hope this helps. :)
umblecumbuz
Re: Correct trim
On the other hand, ventilation is essential for the helmsman, otherwise he will never be correctly trimmed!<br /><br />In which case, he would probably cavitate.... or something.
