Hi. I'm loosing spark on #6 when I take her above 3,000 RPM. We just did a complete overhaul and had no luck with #6 the compression checked out good. I can put in a new spark plug and Idle around and it comes out with a slight brown color then install another new plug and run it up above 3,000 and it looks just as white as it did when it came out of the box -the oil. I have changed out the power pack with one that came off a running motor (loaner) and it didn't help. I switched the carbs around but that was a waste of time. What next maybe $$$$?<br /><br />Tim.
