Sparkplugs - 150 Johnson
dartman
What sparkplugs work well in these OBs? What is the correct NGK plug?
Dhadley
Re: Sparkplugs - 150 Johnson
I would definately recommend sticking with the Champions. I use the QL77JC4's in both my 60 degree and the crossflow 150.<br /><br />You can use the NGK's but I would certianly richen up the carbs, especially in the mid range.<br /><br />Good luck!
Mike Langianese
Whatever brand you decide to use be sure to use a SUPPRESSOR type plug, (the Q designation on the Champion plug). My repair manuals state that failure to do so MAY cause “erratic ignition system operation”. :( <br />Mike
AUGIDAWG
It will idle a little better with the Champion QL78YC (it has a longer nose), and run just a hair hotter, but not too hot like the QL82YC. The larger the number, the hotter the plug.
ob
You never mentioned what 150 hp Johnson you had.These are the Champion plugs recommended by manufacturer.<br /><br />150, 175 (60º V6 Eagle) 1991 & newer QL78YC gap .030 <br />150 Commercial (60º V6 Eagle) 1993 - 2001 QL78YC gap .030 <br />150, 175 Ficht 1997 - 1999 7712 (with non-pinned cylinder heads) .030 <br />150, 175 Ficht 1997 - 1999 XC12PEPB (with pinned cylinder heads) .030 <br />150, 155 (90º crossflow V6) 1978 - 1987 UL77V or L16V Surface Gap N/A <br />150, 175 (90º crossflow V6) 1988 - 1991 QL77JC4 gap .030
dartman
Its a 2002 60º V-6 with carbs.
