Touch-up paint for Model 2000 Johnson 30HP
nordy
Is Johnson " Platinum Spec. 1906" the color I need.<br />If not, what is it ?<br />One could describe the color of my motor as medium grey.
rickdb1boat
Re: Touch-up paint for Model 2000 Johnson 30HP
nordy <br /><br />Might try here for paint, unless you are after OMC original. I've had good luck with Tempo.<br /><br /> web page
tracker14437
nordy<br /><br />I have a 2000 70hp johnson that i think is the same color. Johnson calls it Gun Metal Silver.<br /><br />OMC spray can 772727<br />OMC code 99GSJ1<br />PPG Code 300233 Found at auto parts stores<br /> with PPG paints <br /> Acrylic Enamel only
nordy
Thanks Tracker for Your help.<br />My dealer says, it now will be no problem for him to get the right paint.<br /><br />Many greetings from Germany<br />Nordy
