Re: how can I jumpstart my engine
Yes indeed , the starter cranks fine but it will not start. Ok there's been alot to address. 1st Outboard Jim, it is a 1998 115 60 degree loopcharged Johnson... 2nd, ob , I bought this boat 2years ago had about 25 hours,(it now has 100 to 120hrs) I have never used a lanyard switch although it does have one, I've never used it. If this could be the problem, and a lanyard switch is a saftey devise would the starter still engage. I mean,wouldn't I get the same condition as the neutral saftey switch-Nothing. Not even a crank???? And lastly Hootie, is it ok to assune that since I do not have a big red plug, or cannon plug, I would just disconnect all the little plugs that connect the controls. Its the stopping that sounds tricky. Also, When you say "jumper the solenoid" specifically from where to where do I jumper? Do I need a specific gauge wire to do this? ..... To all, I am tring to be as specific as I know how, I hope this helps. Ken
