Re: explanation sought!!!
rxl123,<br /><br /> I am combining your posts. They ask the same question. Following is your first post and responses. <br /><br />Hi,<br /><br />I have 'too much smoke' on my evinrude 70 1983 coming out the prop. Its blue-ish initially and then becomes slightly less blue. Also get some coming out the 'nostrils' at water level, but this could be steam. Tell tale is cool, but thermostat housing is hot enough to make me think twice about putting a finger on it.<br /><br />If steam, what does this mean? <br /><br />If oily smoke in a non VRO what can cause this if the mixture is OK?<br /><br />Thanks <br />--------------------------------------------------------------------------------<br />Posts: 7 | From: Wiltshire, UK | Registered: Aug 2003 | IP: Logged <br /> <br />rxl123 <br />First Mate <br />Member # 30518 <br /><br /> posted August 21, 2003 06:13 AM <br />--------------------------------------------------------------------------------<br />Also, put new plugs in - had a look and are 'wet and black' not dry and brown.<br /><br />Thanks - help appreciated<br /><br />Gary <br />--------------------------------------------------------------------------------<br />Posts: 7 | From: Wiltshire, UK | Registered: Aug 2003 | IP: Logged <br /> <br />The Marine Doctor <br />Captain <br />Member # 29197 <br /><br /> posted August 21, 2003 09:07 AM <br />--------------------------------------------------------------------------------<br />The engine is running rich.<br /><br />No harm in replacing a thermostat...just in case.<br /><br />TMD <br />--------------------------------------------------------------------------------<br />Posts: 569 | From: SK Canada | Registered: Jul 2003 | IP: Logged <br /> <br />rxl123 <br />First Mate <br />Member # 30518 <br /><br /> posted August 21, 2003 01:58 PM <br />--------------------------------------------------------------------------------<br />Tks Marine Doctor - however I don't quite get you. <br /><br />You suggest replacing a thermostat but the only thermostat I know is the water cooling thermostat. I've got a manual but I can't find any others.<br /><br />Can you expand a little please so I can follow?<br /><br />Ran the boat up in the tank today - it runs a bit lumpy, smokes all the time, particularly under some revs, sneezes occasionally, and when idling in neutral stalls if I select a gear.<br /><br />Any suggestions other than throw it away? I've got new leads new plugs new pump new fuel hose, even appearance on all spark plugs and I'm running out of ideas. Compression is 140, 137, 133<br />Thanks a lot<br /><br />Gary <br />--------------------------------------------------------------------------------<br />Posts: 7 | From: Wiltshire, UK | Registered: Aug 2003 | IP: Logged <br /> <br />2K BOAT <br />Captain <br />Member # 5118 <br /><br /> posted August 21, 2003 03:34 PM <br />--------------------------------------------------------------------------------<br />mite need to rebuild carbs. <br />--------------------------------------------------------------------------------<br />Posts: 608 | From: charleston, sc | Registered: Nov 2001 | IP: Logged <br /> <br />The Marine Doctor <br />Captain <br />Member # 29197 <br /><br /> posted August 21, 2003 04:08 PM <br />--------------------------------------------------------------------------------<br />The carbs are delivering to much fuel.<br /><br />Remove them and clean and rebuild them.
