1973 Evinrude Power loss / missing
zukimud1
I have a 1973 Evinrude 70hp that has started acting up. When I first put it in the water it runs fine. When I put it at full throttle it runs great for about 1/4 of a mile and then starts missing really bad. When it does this it makes a rattling noise and loses power. If I try to give it throttle is just bogs down. After it does this it goes slow (just popped into gear) just fine, with a miss about every 15 seconds. By the way, it runs great without a load on it. I have taken it to a mechanic and he has done the following:<br /><br />Checked compression...good<br />Changed fuel pump<br />Cleaned out fuel filter<br />Rebuilt the carbs<br />Tried different gas<br /><br />After he did this stuff, I took it to the lake and it was exactly the same. Any help would be appreciated.<br /><br />Thanks
zukimud1
Re: 1973 Evinrude Power loss / missing
I just read another post from a guy that had almost the same problem as me, and he said the magneto fixed it. Is the magneto the same as a power pack?
JG18
It almost sounds like you have a float stuck. <br /><br />By this I mean, as the motor sits it has time to fill the bowl. When you run the motor the bowl becomes empty, and it causes the miss. To verify start and run motor until it starts to miss. Spray a little carb cleaner in each of the carb intake barrels, one at a time. If the motor picks up on one of teh barrels check float.
zukimud1
That makes sense, but the mechanic has rebuilt the carbs. Wouldn't that pretty much take the float out of the picture? I talked to him today, and he said he is going to try a new power pack.
carmangary1
I have a similar problem so if you figure it out please post the results.
papasage
my 74 was breaking down and loosing power after a short run . let it sit for a while maby 5 minutes it would go full throddle and break down after a short full throddle . replaced a coil and rectofier it ran great . papasage
