1962 V-4 75 HP. evinrude. timming help plese?? I hate outbords!!!
mjv_fireball
I've lined uo the fly weel with the mark on the mater jackit cover. And the distributer weel with the mark on the bract that holdes the distributer in place. New cap, points, wires, and plugs.(J4C). Coil is good. Compreshion is good. And the carb is clean. She will not fire, or start. Using the thimming lite. I see there is spark in wires 1 & 3. But nothing in wires 2 & 4. What am I doing wromg. :confused: :confused: MJV :confused: :confused: Mix set at 50:1.
mjv_fireball
Re: 1962 V-4 75 HP. evinrude. timming help plese?? I hate outbords!!!
faceing forword port side is left? or right??
mjv_fireball
I thank I'm going to smash this pice of s**t
Joe Reeves
Port is left. Easy way to keep that straight is that both words consist of four (4) letters.<br /><br />Standing in back of the boat, looking at the engine, port is to your left, starboard is to your right.<br /><br />Cylinders 1 and 3 are starboard cylinders. Cylinders 2 and 4 are port cylinders.
Hooty
Standing at the back of the boat facing forward, port is the left side (watch-hand if you're right handed). :D P-O-R-T = four letters, <br />L-E-F-T = four letters.<br /><br />Wish I could be more help.<br /><br />g'luck & c/6<br /><br />Hooty
mjv_fireball
thanks I'm at the end of my rope with this thing. I know where all the marks are now but can'get the thing to start. I think I'm going to up the mix, from 50:1 to 30:1. thats the only thing I have not tryed. mjv
mjv_fireball
well that did'nt help. I have my mix back to a 24:1. crankes better but still woun't start
mjv_fireball
Well thanks guys. I now know whats wrong, and exacty how to fix. The problem is I don't know what the h@#l i'm doing. So the only way I'm going to get this thing going , is to bring it in, and have some one that knows what to do. Have them fix it right. :mad: :( :eek: . Don't get me wgong this is a grate site, with a lot of good pepole, who know there motters. But I know when I'm in over my head.
lonemust
make sure points are clean and set at .020 had same problem cleaning points solved it
OK - Dumb question, you have cleaned and set both sets of points?
If so, look for arcing on plug wires, cracked insulation. Check ground of spark plugs.
