FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
1996 Johnson 115 hp.<br />I am having a tough time removing the impeller on the water pump. It seems to be stuck to the shaft. Any tricks for removing these?
Get some good pentetrating oil and soak down between impeller hub and shaft.Let sit for spell and see if you can tap around on impeller hub nearest shaft as possible and see if she'll work loose.
Walker,<br />Turning it clockwise while holding the shaft did the trick, it went click and I slid it right off.<br />Thanks a bunch, you saved me a whole lot of aggrivation.
