Hi:<br /><br />I have always run Merc's and have been able to trim them all the way up and all the way down while under way at any speed.<br /><br />I just bought a used 1985 Johnson 175 V6 O/B and can trim it fully up at low speeds, but have a limited trim range at higher rpm's. if the engine is trimed up so the prop is close to the surface and i start to go faster the engine automatically trims down. I only can trim it fully down or up only a few inches from the fully down position.<br /><br />Is this normal for this outboard? I never had one like this. The engine does fully trim up when it's off and docked.<br /><br />thank you for help
