FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
1979 Johnson Seahorse 4 H.P. model# 4w79d<br />Runs like a champ and this is the first time out on the water with it. I noticed it dosent pee very much. There are 6 tiny holes in the back that just kind of spit water out? is this the way it works?
Re: Johnson seahorse has trouble with cooling water tell-tale
it spits at idle and spits alot harder at full throttle. Im used to seeing a stream of water out the back of motors. but, I guess being this small there wouldnt be that big of a spray?<br /><br />Suzuki40
i have a 9.5 that just kinda spits i think that it has an exhuast bypass that u get water and exhaust out of the holes if its not over heating its working but if you have any doughts change it they are cheap
Its not overheating. its just 6 little holes 3 on each side of the back of the shaft housing. There is also a trickle of oil that runs out of those holes too, just a little.<br /><br />Suzuki40
dark oil ??? it sounds like your engine works like mine what you are seeing is oil(per mix) from the exhuast.did you drain the lower unit just to make sure outs not a bad seal in the lower unit ??
the oil is a light brown color. but, of course it mixed with water. My lower unit oil, I assume you are talking about the gearcase above the skeg? The oil in there is blue. and when I check it it's blue?<br /><br />Suzuki40
Suzuki,<br />The small amount of spray you see comming from those 6 little holes is perfectly normal. If you can hold your hand near those holes and your hand gets wet, you're good to go. That motor doesn't have a thermostat or an "overboard indicator" (pee stream), just those little vent holes.
