dtorres103
- Jul 25, 2002
- 6
I have a 83 70hp evinrude on a pipestone mariner 15 foot boat that was given to me from a friend. It was sitting for about 10 years before I got a hold of it. I changed the water pump, changed the oil in the lower unit, new spark plugs, new gas tank, new primer bulb and hose to and from tank.<br />It starts fine and seems to idle a little low after lowering fast idle lever. Went to the local lake and launched it but can only cruise at low speed, once the throttle is pushed forward it starts to die out, when pulling back on the throttle it will cruise at low speed again. It does not miss at all. I suspect the fuel pump may be the problem. I didn't know about squeezing the primer bulb when I had it on the lake to rule out the pump but it seems odd that it runs fine at idle but cannot run at higher throttle levels. The fuel filter screen is clean. Thoughts anyone?
